MMoexp: EA FC 25: All the New Skill Moves and How to Excel with Them
Posté : mar. 14 janv. 2025 03:54
With the launch of EA FC 25 just around the corner, players can look forward to a variety of new gameplay features, particularly in the skill move department. This season introduces four exciting new techniques that promise to enhance your gameplay experience. Let's dive into these fresh skills and learn how to utilize them effectively on the field.
Big Feint (2 Stars)
First up is the Big Feint, a dynamic dribbling skill designed to help players swiftly change direction and throw off defenders. To execute this move, hold the L2/LT button, flick the right stick left or right, and then use the left stick to choose your exit direction.
Mastering the Big Feint hinges on your timing and precision. When done right, it creates a sharp change in pace and direction, leaving defenders struggling to recover. With a 2-star rating, this move is accessible to many players, making it ideal for both those new to skill moves and seasoned dribblers looking to add flair.
Stop and Go (2 Stars)
Next is the Stop and Go, a versatile move that allows players to halt abruptly and then accelerate in a new direction. To perform it, hold the L2/LT button, push the right stick back, then forward.
This move is particularly effective for creating space and navigating around defenders. The quick stop followed by a sudden burst can catch opponents off guard, setting you up for a key pass or a shot on goal. Since the Stop and Go can be canceled, it seamlessly integrates with other actions, enhancing your overall gameplay.
Step Over Ball (4 Stars)
The Step Over Ball is a more advanced skill that requires a bit of finesse. To pull it off, hold the L1/LB button and flick the right stick forward, then either left or right.
This move is excellent for one-on-one situations against defenders. By dragging the ball across your body and shifting your weight, you can create space and leave opponents behind. The 4-star rating reflects its complexity, but mastering it can be a game-changer when facing skilled opponents.
Toe Drag Stepover (5 Stars)
Finally, we have the Toe Drag Stepover, the most intricate new skill move in EA FC 25. To execute this, spin the right stick in a specific pattern—either right, back, left or left, back, right—while holding the L1/LB button.
This move showcases exceptional ball control and body feints, making it a true spectacle on the pitch. When timed perfectly, the Toe Drag Stepover can bewilder defenders, opening up significant space for attacking players. Its 5-star rating indicates the high skill level needed, positioning it as a technique for the game's elite players.
As you gear up for the release of EA FC 25, dedicate time to practice these new moves. With commitment and perseverance, you'll soon be executing them with https://www.mmoexp.com/Fc-25/Coins.html ease, ready to dominate the competition.
Big Feint (2 Stars)
